Právě je čtv čer 25, 2026 9:23 am
Odeslat nové téma Odpovědět na téma  [ Příspěvků: 36 ]  Přejít na stránku Předchozí  1, 2, 3
 Předmět příspěvku: Re: Elite Dangerous
PříspěvekNapsal: stř bře 09, 2016 10:11 am
Díky, můj cargo max cutter na krátké vzálenosti zde:
http://coriolis.io/outfit/imperial_cutter/27A7A7A7D6A7D5C1f1f1f1c1c1c1c00020j090302--070705050504040302.Iw18ZZA=.Aw18ZZA=?bn=cutter_cargo_max_short
Mimochodem ty military grade bulkheads jsou vyborny, kdyz se nad tou krávou ztrati kontrola a nekam se to v rychlosti narve :) .... jeste je mozny k tomu pridat hull reinforcements, ale tohle je cargo max.
PříspěvekNapsal: pon dub 11, 2016 1:07 pm
...neříkám nic, ale na mojé slova občas dojde :cool:
PříspěvekNapsal: ned črc 24, 2016 1:28 pm
Když se řekne A je třeba taky říct B. :)
Tenhle komentář pod videem řekne o účinnosti zbraní mnohem víc:
"Did some number crunching. If you could fire each of these for 60 seconds non stop using numbers in the video these would be the numbers for each.In 60 seconds:Pulse 50.2% Hull, 143.1% ShieldsBurst 71.5% Hull, 168.9% ShieldsBeam 79.1% Hull, 200% Shields
If we have pulse as stock it would mean:Burst does +42.3% Hull, +18% ShieldsBeam does +57.5% Hull, + 39.7% Shields
Now if we increase the time pulse shoots from 23.9 to 60 seconds. And increase both burst and beam by the same percentage. You'd have this.If pulse can shoot for 60 seconds consecutively then:Burst can for 46.37s = 77.28% time pulse can shoot.Beam can for 32.39 = 53.97% time pulse can shoot.
So:Burst has a 22.72% increase in power drain.
Beam has a 46.03% increase in power drain.
Burst = +42.3% to hull. +18% to shield at 22.72% more power drain.Beam = +57.5% to hull. +39.7% to shields at 46.03% more power drain.
This is just from the numbers from this video. Obviously doesn't show the difference between fixed/gimballed/turreted. I'd guess the damage% between pulse/burst/beam stays the same for all mounts, but the overall damage% is lowered from fixed-turreted. Hope this helps.
CMDR ShaneRoberts010"
Ano pulz skutečně je schopnější pálit kontinuálně to ovšem i jiné lasery tam jde o power distributor, jeho schopnost doplňování energie a odběr zbraní z něj.
A pokud k tomu ještě vezmeš v úvahu turrety a to, že pulzní mají ze všech nejhorší rating tzn že jejich přesnost střelby je ze všech turretu nejhorší v rámci velikosti např 3 mají F burst E a beam D tak ve finále se dostáváme na úplně jiný čísla ;)
PříspěvekNapsal: stř srp 03, 2016 5:09 pm
Bude mne to za tech 25€ bavit? :D
PříspěvekNapsal: čtv srp 18, 2016 9:45 pm
To si piš :-)
PříspěvekNapsal: ned srp 21, 2016 2:11 pm
313_Otto píše:
Na ZX Spectrum jsem to dotahl do hodnosti Elite :D Ale byly to kyble hodin hrani :D
