Právě je sob zář 12, 2026 5:49 am
Odeslat nové téma Odpovědět na téma  [ Příspěvků: 95 ]  Přejít na stránku Předchozí  1, 2, 3, 4, 5 ... 7  Další
PříspěvekNapsal: sob úno 17, 2007 7:11 pm
313_Pycko píše:
I can't find solution for my problem in this FAQ section ...
You must send me detailed informations about your computer, software that you have installed and detailed informations about your problem. HyperLoby generate in to instalation folder the verinfo.txt file that you MUST include in to bugreport...
An example:
Problem: I'am getting "run-time error XX" when ....
Computer manufacturer: home
CPU: Celeron 366 overclocked to 550
RAM: 196 MB
HDD: Western Digital 20GB
VGA: Voodoo 3 3000
OS: Windows 98 SE Slovakish
Games: WWII Fighter, USAF, F-15
HL Version: 2.1.33
Internet Explorer version: 5.1
etc, etc ,...
verinfo.txt file example contens:
Win 9x: 4.10.40A08AE - A
hlpro.exe 3.7.0.222
aping.exe 1.0.0.16
dexec.exe 1.0.0.5
mswinsck.ocx 6.0.89.88
msvbvm50.dll 5.1.43.19
asycfilt.dll 2.40.4277.1
comcat.dll 5.0.1601.1
ctl3d.dll 2.31.0.0
ctl3dnt.dll No Version Info available!
oleaut32.dll 2.40.4277.1
olepro32.dll 5.0.4277.1
stdole2.tlb 2.40.4277.1
This report you must send in to Technicall Support Forum . Any emails including a problem report i will ignore.
Na tvoju chybu je v HL tech forum táto odpoved:
Kód:
Re: Error 10060 timeout
Posted: Wed Apr 13, 2005 9:49 am
Jiri-Fojtasek
         Scorp wrote:
I've been graced with this problem for bout half a week now.
I've NEVER had a problem with hyperlobby before.
I've been using hyperlobby for about 2 years now i think.
It seemed to happen right after:
I disabled my network connection while hyperlobby was running
I then reenabled it.
Tried to reconnect to hyperlobby.
Timeout started.
This problem(my case) is not related to my isp.
I've seen posts about this being isp related ,etc...
I've tried all the tricks I know to fix this.
Reinstall of HL, playing with network settings blah blah blah.
I've read all the posts about this problem in these forums.
Is there no fix for this?
Is there some registry setting that might help?
I've being trying the 2 latest versions of hl
win xp pro
sp2
roadrunner cable
[b]When you reinstall the HL, you need also reconfigure your firewall to allow HL acces to the internet[/b]
Pycko a teď pro ty s mezerama ve vzdělání česky neb slovensky :shock:
PříspěvekNapsal: sob úno 17, 2007 7:12 pm
Pánové tak nemůžu se připojit na Hyperloby, dokonce ani na http://hyperfighter.sk !!!!!! a ted si lámejte hlavy!!!!! vždy stejná odpověd: Error Socket: 10060 The attempt to connect timed out nebo "časový limit vyprše"
Jsem na tom stejně, a to jsem HL i přeinstaloval :wink:
PříspěvekNapsal: sob úno 17, 2007 7:39 pm
313_Blc píše:
Fíha ... nechceš jít přesvědčovat i ke mně? :D
neni treba-zkus jako ja pohrozit tim,ze misto na pojistovnu v ruzovy ulici se bude koukat na valecny filmy a dokumenty :wink:
LOL
PříspěvekNapsal: ned úno 18, 2007 8:39 pm
313_Trim píše:
Tak že, Hyperloby nešlo ,protože jsem asi cca.4 dni před tím zkoušel Comodo Personal Firewall a ten šmejd se mi usadil v systemu takovým způsobem,že i když jsem ho odinstaloval tak to nehodlal akceptovat a vesele fungoval dál a ještě drze nahradil sys.firewall XP. Normálně byl zašitej hluboko v registru a běžným způsobem nešel najít,když jsem ho nakonec našel tak tak se surově bránil jakémukoliv odmazání. Ve finále došlo k přeinstalování Woken,Hyperloby maká normálně :twisted:
PříspěvekNapsal: pon úno 19, 2007 6:44 am
Se dívám, že Format C: je fakt univerzální :D
To já měl problém, že mi zničehonic přestal fungovat IL2 při pokusu se kdekoliv připojit. A nakonec to bylo tím, že sme den předtím instalovali na zkoušku programek Hamachi. Ten nesmysl sem odinstaloval a vše zas jede jak má ...
PříspěvekNapsal: pon úno 19, 2007 7:58 am
tvému problému vůbec nerozumím a tudíž
se k němu nebudu vyjadřovat
jen tady chci vyjádřit svou podporu a svůj zájem na řešení
ps: vo co de?
PříspěvekNapsal: pon úno 19, 2007 8:44 am
313_Blc píše:
Ty mas potom nejekho specialneho Hamachi ;)
PříspěvekNapsal: pon úno 19, 2007 5:43 pm
313_Trim píše:
Tak vám řeknu co jsem uděla, aby mi to šlo.
1. Zavolal jsem providery, abych zjistil, zda neblokuje nějaké porty => ne
2. Odinstaloval jsem HL
3. start=>spustit=>cmd=>ipconfig /flushdns (poradil mi to ITík u nás v práci)
4. Zkusil jsem, zda mi naběhnou stránky http://hyperfighter.sk => ANO
5. Nainstaloval jsem HL => šlape to, lítá to
....jo jo pak, že formát C...
:lol:
PříspěvekNapsal: stř bře 21, 2007 7:00 pm
tak sem si ten svůj soustruh trochu vylepšil:
Athlon 64 X2 Dual 3800+
GF 7600GT
DDR2 2x 512 / 800MHz Dual
HDD Western 250GB/7200/16Mb cache
navíc mi nezbylo :cry:
PříspěvekNapsal: stř bře 21, 2007 7:40 pm
Tak mi ty součástky ze starého soustruhu pošli wole :)
PříspěvekNapsal: stř bře 21, 2007 8:41 pm
Týý jo! To už snad lítá Ila samo ne?
PříspěvekNapsal: stř bře 21, 2007 9:28 pm
WTG to je delo!
PříspěvekNapsal: čtv bře 22, 2007 12:46 am
ee uz s nima mam jiny plany,zbyde mi jen grafarna GF 6600 a tu asi soupnu deckam do compu
jinak to asi pude,ted sem testoval na AH a stabilne to drzelo 77fps pri max nastaveni
zbejva doladit par drobnosti/napr. mi neslape mic / a muzem to testnout na vostro
PříspěvekNapsal: čtv bře 22, 2007 1:37 am
zhluboka tě nenávidím Machere... :lol:
Závidím a vsteky rudnu :twisted:
PS: užij si comp a aspoň mi ho vyfoť, ptotože ten můj půjde za chvíli z okna :lol:
PříspěvekNapsal: čtv bře 22, 2007 6:54 am
Tak se pak ozvi Fajtlíku, budu čekat dole ... :wink:
